Crashlog vom G4 DP 1,25 GHz (10.4.11)
Hi!
Kann mir jemand bei der Übersetzung des Crashlogs behilflich sein?
Hier isses (nachdem ich den Mac auf sein Geheiss hin mit langem drücken des Einschaltknopfs zum Schweigen gebracht habe):
Unresolved kernel trap(cpu 1): 0x300 - Data access DAR=0x0000000000000010 PC=0x00000000000665E4
Latest crash info for cpu 1:
Exception state (sv=0x43F79280)
PC=0x000665E4; MSR=0x00009030; DAR=0x00000010; DSISR=0x40000000; LR=0x00066570; R1=0x2C5CB920; XCP=0x0000000C (0x300 - Data access)
Backtrace:
0x032E4640 0x00070640 0x00087DCC 0x002D672C 0x002D6580 0x00851174
0x00850D54 0x00845514 0x002EC884 0x0008CA28 0x00029234 0x000233F8 0x000ABEAC 0x00000000
Kernel loadable modules in backtrace (with dependencies):
com.apple.ATIRadeon8500(4.1.8 )@0x83c000
dependency: com.apple.iokit.IOPCIFamily(1.7)@0x491000
dependency: com.apple.iokit.IOGraphicsFamily(1.4.2)@0x777000
dependency: com.apple.iokit.IONDRVSupport(1.4.2)@0x79b000
Proceeding back via exception chain:
previously dumped as “Latest” state. skipping…
Exception state (sv=0x44030780)
PC=0x9000B348; MSR=0x0000F030; DAR=0xE4BFD000; DSISR=0x42000000; LR=0x9000B29C; R1=0xBFFEC730; XCP=0x00000030 (0xC00 - System call)
Kernel version:
Darwin Kernel Version 8.11.0: Wed Oct 10 18:26:00 PDT 2007; root:xnu-792.24.17~1/RELEASE_PPC
panic(cpu 1 caller 0xFFFF0003): 0x300 - Data access
Latest stack backtrace for cpu 1:
Backtrace:
0x000954F8 0x00095A10 0x00026898 0x000A8204 0x000ABB80
Backtrace:
Kernel version:
Darwin Kernel Version 8.11.0: Wed Oct 10 18:20Model: PowerMac3,6, BootROM 4.4.8f2, 2 processors, PowerPC G4 (3.3), 1.25 GHz, 2 GB
Graphics: ATI Radeon 9000 Pro, ATY,RV250, AGP, 64 MB
Memory Module: DIMM0/J21, 512 MB, DDR SDRAM, PC2600U-25330
Memory Module: DIMM1/J22, 512 MB, DDR SDRAM, PC2600U-25330
Memory Module: DIMM2/J23, 512 MB, DDR SDRAM, PC2600U-25330
Memory Module: DIMM3/J20, 512 MB, DDR SDRAM, PC2600U-25330
Modem: Dash2, Euro, V.92, 1.0F, APPLE VERSION 2.6.6
Network Service: Ethernet (integriert), Ethernet, en0
Parallel ATA Device: HL-DT-ST DVD-RW GCA-4020B
Parallel ATA Device: IBM-IC35L120AVVA07-0, 115.04 GB
USB Device: Hub, Up to 12 Mb/sec, 500 mA
USB Device: Hub in Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 500 mA
USB Device: Apple Optical USB Mouse, Mitsumi Electric, Up to 1.5 Mb/sec, 100 mA
USB Device: Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 250 mA
:kopkr: Irgendwas ist da im Grafik-Subsystem schief gelaufen. Was hast Du denn vor dem Crash gemacht? Eventuell weiß der erweiterte Hardware-Test von der Mac OS X DVD mehr?
Morsche,
der erweiterte HW-Test brachte mehrfach keine Ergebnisse, Rember allerdings bricht ab, ohne nen Fehler zu loggen.
Passiert ist das ganze beim (nicht erstmalig an diesem Tag) öffnen des Dashboards (F12), allerdings hab ich da schon lang nichts mehr verändert… und warum steht am Anfang des Logs mal was von CPU1?
Weil der code der den fehler produzierte gerade auf cpu1 abgearbeitet wurde.
Hi!
Also, ich habe Rember jetzt noch mal mit den ursprünglichen 1 GB RAM (alles i.O.), zusätzlich mit einem von 2 (seit letzte Woche eingebauten zusätzlichen) 512 RAM (also 1,5GB, immer noch alles OK, allerdings dauerte der Test nicht mehr 10 Min sondern ca. 75 Min). Im Moment läuft Rember mit 2 GB RAM, mal schauen…
Meint ihr, mensch kommt da irgendwo näher dahinter, was mit der GraKa o.ä. sein könnte?
So, RAM scheint i.O., nach ca. 2 h war der Test mit 2 GB erfolgreich durchgelaufen.
Mein Problem sind zudem regelmäßige System-Freezes, d.h. der Rechner friert komplett ein, funzt aber, nach nem kalt ausschalten und neustarten, durchaus auch nen ganzen Tag, um dann doch nochmal stehen zu bleiben. Welche Logs wären da denn noch interessant? Das System-Crash-Log z.B. hab ich erst seit gestern… :nopla:
Gibt denn system.log (erreichbar über Konsole oder /var/log/system.log) noch was her?
Schau ich morgen mal nach…
Hi!
Hier das System-Log von heute eben gerade, nach dem Einschalten heut früh ist er einmal gefrostet und läuft seitdem…
system.log:
Beschreibung: Protokoll der Systemereignisse
Größe: 11.85 KB
Zuletzt geändert: 31.01.08 10:23
Letzte Einträge: …
Jan 31 08:12:02 localhost DirectoryService[53]: Launched version 2.1 (v353.6)
Jan 31 08:12:03 localhost kernel[0]: Security auditing service present
Jan 31 08:12:03 localhost kernel[0]: BSM auditing present
Jan 31 08:12:03 localhost kernel[0]: disabled
Jan 31 08:12:03 localhost kernel[0]: rooting via boot-uuid from /chosen: 7A65FEAE-1EB2-3751-951A-E807A8249A95
Jan 31 08:12:03 localhost kernel[0]: Waiting on IOProviderClassIOResourcesIOResourceMatchboot-uuid-media
Jan 31 08:12:03 localhost kernel[0]: Got boot device = IOService:/MacRISC2PE/pci@f4000000/AppleMacRiscPCI/ata-6@D/AppleKauaiATA/ATADeviceNub@0/IOATABlockStorageDriver/IOATABlockStorageDevice/IOBlockStorageDriver/IBM-IC35L120AVVA07-0 Media/IOApplePartitionScheme/Ohne Namen 4@12
Jan 31 08:12:03 localhost kernel[0]: BSD root: disk0s12, major 14, minor 10
Jan 31 08:12:03 localhost lookupd[52]: lookupd (version 369.5) starting - Thu Jan 31 08:12:03 2008
Jan 31 08:12:03 localhost kernel[0]: Jettisoning kernel linker.
Jan 31 08:12:03 localhost kernel[0]: Resetting IOCatalogue.
Jan 31 08:12:03 localhost kernel[0]: Matching service count = 0
Jan 31 08:12:03 localhost kernel[0]: Matching service count = 2
Jan 31 08:12:03 localhost kernel[0]: rtclock timebase_callback: late old 1000000000 / 41657508 new 1000000000 / 41657239
Jan 31 08:12:03 localhost kernel[0]: PRAM: BootBeepVolume property set to 1.
Jan 31 08:12:03 localhost kernel[0]: IPv6 packet filtering initialized, default to accept, logging disabled
Jan 31 08:12:04 localhost xinetd[44]: xinetd Version 2.3.11 started with libwrap options compiled in.
Jan 31 08:12:04 localhost xinetd[44]: Started working: 0 available services
Jan 31 08:12:04 localhost kernel[0]: UniNEnet: Ethernet address 00:0a:95:9c:82:cc
Jan 31 08:12:04 localhost launchd: Server 3f2b in bootstrap 1103 uid 0: “/usr/sbin/lookupd”[52]: exited abnormally: Hangup
Jan 31 08:12:04 localhost lookupd[76]: lookupd (version 369.5) starting - Thu Jan 31 08:12:04 2008
Jan 31 08:12:04 localhost diskarbitrationd[47]: disk0s9 hfs EF1BC665-6FFA-3B3E-ABF9-B0155E9C937F Daten /Volumes/Daten
Jan 31 08:12:05 localhost diskarbitrationd[47]: disk0s10 hfs 11C6BB8F-8AF3-357B-A2EB-FBBC5F0ABC85 Mac OS 9 /Volumes/Mac OS 9
Jan 31 08:12:05 localhost diskarbitrationd[47]: disk0s11 hfs 61BF2B82-2B32-3E94-987E-75DF8AE81CDA Schriften /Volumes/Schriften
Jan 31 08:12:05 localhost diskarbitrationd[47]: disk0s12 hfs 7A65FEAE-1EB2-3751-951A-E807A8249A95 Mac OS X /
Jan 31 08:12:06 localhost kernel[0]: ATY,Pheonix_A: vram [9c000000]
Jan 31 08:12:06 localhost kernel[0]: ATY,Pheonix_B: vram [98000000]
Jan 31 08:12:06 localhost /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow: Login Window Application Started
Jan 31 08:12:06 localhost kernel[0]: UniNEnet::monitorLinkStatus - Link is up at 100 Mbps - Full Duplex
Jan 31 08:12:06 localhost configd[45]: AppleTalk startup
Jan 31 08:12:06 G4-DP-1-25Ghz configd[45]: setting hostname to “G4-DP-1-25Ghz.local”
Jan 31 08:12:06 G4-DP-1-25Ghz loginwindow[87]: Login Window Started Security Agent
Jan 31 08:12:09 G4-DP-1-25Ghz launchd: Server 0 in bootstrap 1103 uid 0: “/usr/sbin/lookupd”[76]: exited abnormally: Hangup
Jan 31 08:12:09 G4-DP-1-25Ghz configd[45]: executing /System/Library/SystemConfiguration/Kicker.bundle/Contents/Resources/enable-network
Jan 31 08:12:09 G4-DP-1-25Ghz configd[45]: posting notification com.apple.system.config.network_change
Jan 31 08:12:09 G4-DP-1-25Ghz lookupd[105]: lookupd (version 369.5) starting - Thu Jan 31 08:12:09 2008
Jan 31 08:12:09 G4-DP-1-25Ghz kernel[0]: PRAM: BootBeepVolume property set to 1.
Jan 31 08:12:09 G4-DP-1-25Ghz anacron[173]: Anacron 2.3 started on 2008-01-31
Jan 31 08:12:09 G4-DP-1-25Ghz anacron[173]: Normal exit (0 jobs run)
Jan 31 08:12:09 G4-DP-1-25Ghz configd[45]: AppleTalk startup complete
Jan 31 08:12:10 G4-DP-1-25Ghz configd[45]: target=enable-network: disabled
Jan 31 08:12:10 G4-DP-1-25Ghz VersionCueCS2Daemon[194]: warning: VersionCueCS2Daemon not started by mach_init process (parent pid: 1)
Jan 31 08:12:11 G4-DP-1-25Ghz mDNSResponder: Adding browse domain local.
Jan 31 08:13:47 G4-DP-1-25Ghz kernel[0]: IOAudioStream[0x2f7fc00]::clipIfNecessary() - Error: attempting to clip to a position more than one buffer ahead of last clip position (0,df8)->(1,1063).
Jan 31 08:13:47 G4-DP-1-25Ghz kernel[0]: IOAudioStream[0x2f7fc00]::clipIfNecessary() - adjusting clipped position to (1,df8)
Jan 31 10:22:41 G4-DP-1-25Ghz /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow: Login Window Application Started
Jan 31 10:22:43 G4-DP-1-25Ghz loginwindow[498]: Login Window Started Security Agent
und hier nochmal das Crash-Log von eben:
panic.log:
Beschreibung: Panic-Protokoll (Systemabstürze)
Größe: 4.12 KB
Zuletzt geändert: 31.01.08 07:58
Letzte Einträge: Tue Jan 29 12:34:15 2008
Backtrace:
Kernel version:
Backtrace:
Backtrace:
Kernel version:
Thu Jan 31 07:58:04 2008
Latest crash info for cpu 0:
Exception state (sv=0x4FD1E280)
PC=0x002B33CC; MSR=0x00089030; DAR=0x41F18000; DSISR=0x40000000; LR=0x007C3D38; R1=0x2C533A20; XCP=0x0000001C ()
Backtrace:
0x007C3C04 0x007C3EFC 0x007C45E8 0x007BAFD8 0x007B9C14 0x007B9BB0
0x002D1B8C 0x002D0A54 0x000A9714
com.apple.driver.ApplePMU(2.3.4d1)@0x7b8000
dependency: com.apple.iokit.IOHIDFamily(1.4.13)@0x4a9000
Exception state (sv=0x41EE8A00)
PC=0x00000000; MSR=0x0000D030; DAR=0x00000000; DSISR=0x00000000; LR=0x00000000; R1=0x00000000; XCP=0x00000000 (Unknown)
Kernel version:
panic(cpu 0 caller 0xFFFF0007):
Latest stack backtrace for cpu 0:
Backtrace:
Backtrace:
Kernel version:
Ich kann dir nicht helfen, und ich glaube auch kaum das einer hier im forum sonderlich viel hilfreiches aus den logs lesen kann.
Nichts gegen die akiven hier, aber um aus den crashlogs was raus zu lesen ist es schon sehr hilfreich wenn man bei der entwicklung des betreffenden systems beteiligt ist.
Und ich vermute einfach mal das keiner hier ein OSX kernel entwickler ist. :smile:
Ich wuerde mal ne mail mit den logs und fehlerbeschreibung an apple schicken, vllt schaut ja wer drueber und kanns eher eingrenzen.
Der crash eben ist diesmal nicht von der GPU ausgegangen, hmm…
so schnell geb ich die Hoffnung aber nicht auf :w00t: !
Ich hoff dir stibt die hardware ned ab, waer schade bei nem oldie wie diesem.
Schonmal ein frisches OSX drauf gemacht und erstmal komplett ohne zusaetzliche software und treiber getestet ob die kiste damit stabil laeuft?
Der letzte Crash war ein HID-Gerät - Tastatur oder Maus. Hängt da irgendwo ein USB-Hub dazwischen, den man mal tauschen oder auslassen könnte?
Einen PMU-Reset hast Du wahrscheinlich auch schon gemacht, oder?
Ich glaube nicht das es ein usb geraet war, da die PMU ja mehr macht als man vom namen her vermuten wuerde.
config ADB_PMU
bool “Support for PMU based PowerMacs”
depends on PPC_PMAC
help
On PowerBooks, iBooks, and recent iMacs and Power Macintoshes, the
PMU is an embedded microprocessor whose primary function is to
control system power, and battery charging on the portable models.
The PMU also controls the ADB (Apple Desktop Bus) which connects to
the keyboard and mouse on some machines, as well as the non-volatile
RAM and the RTC (real time clock) chip. Say Y to enable support for
this device; you should do so if your machine is one of those
mentioned above.
kernelfr.traduc.org/ftp/2.6.15/a … sh/Kconfig
War das erste was ich in dem bezug gefunden hab :smile:
[quote=“xfile666”]
Ich glaube nicht das es ein usb geraet war, da die PMU ja mehr macht als man vom namen her vermuten wuerde.[/quote]
Der letzte war ein
…die Dependency ist aber
:nopla:
so, der G4 ist jetzt nen ganzen Tag, auch nach mehrmaligem runterfahren-auslassen-hochfahren nicht mehr gefreezt… war den ganzen Tag kaum am Rechner, hab aber zur “Belastung” mal BOINC konstant rennen gehabt.
Ich versuche gerade ne USB-Verlängerung hier in der Firma aufzutreiben, da bei mir die MMouse an der Tastatur und die Tastatur (zum Verlängern) an nem USB-Hub hängt! Im Moment steht der Rechner n Stück weiter vorne und ich versuchs erst mal direkt Tastatur–>Rechner.
Aber Ihr macht mir irgendwie Hoffnungen, das eigentlich alles i.O. ist… PMURam-Reset müsste ich allerdings noch machen, soll ich jetzt oder nicht und wenn ja wie?
Edit: Gibt keine USB-Verlängerung…
Hi!
Also, jetzt hat ers den ganzen Tag getan, wir machen jetzt beide Feierabend und schauen dann Morgen, ob er sich nochmal verschluckt! :grabs:
