Kernel Panic bei Time Machine
wenn Time Machine zum ersten Mal läuft (Generalbackup) kommt es “immer”
zur Kernel Panic. Mal schon bei 6 GB, mal erst bei 45 GB. Hier der Bericht:
Mon Nov 19 22:36:42 2007
panic(cpu 0 caller 0x001A7BED): Kernel trap at 0x0041e1bb, type 14=page fault, registers:
CR0: 0x8001003b, CR2: 0x0000000c, CR3: 0x0101f000, CR4: 0x00000660
EAX: 0x00000000, EBX: 0x03fa3380, ECX: 0x0061e216, EDX: 0x345e7bdc
CR2: 0x0000000c, EBP: 0x345e7b58, ESI: 0x03fa3388, EDI: 0x03fa3390
EFL: 0x00010206, EIP: 0x0041e1bb, CS:  0x00000008, DS:  0x04100010
Error code: 0x00000002
Backtrace, Format - Frame : Return Address (4 potential args on stack)
0x345e7948 : 0x12b0e1 (0x455670 0x345e797c 0x133238 0x0)
0x345e7998 : 0x1a7bed (0x45ea20 0x41e1bb 0xe 0x45e1d4)
0x345e7a78 : 0x19e517 (0x345e7a90 0x345e7b54 0x345e7b58 0x41e1bb)
0x345e7a88 : 0x41e1bb (0xe 0x4100048 0x345e0010 0x340010)
0x345e7b58 : 0x41da73 (0x3fa3380 0x345e7bdc 0x0 0x0)
0x345e7ba8 : 0x41e3f4 (0x3fab640 0x41e15e 0x345e7bdc 0x0)
0x345e7bf8 : 0x6130cc (0x3fa3380 0x0 0x345e7c28 0x3e72800)
0x345e7c68 : 0x61750e (0x3e72800 0x4826200 0x5 0x411038c)
0x345e7ca8 : 0x91e1f8 (0x4110380 0x4826200 0x7530 0x7530)
0x345e7d08 : 0x91e3b6 (0x40c2400 0x40c24e4 0x4 0x3ff1f80)
0x345e7d48 : 0x612350 (0x40c2400 0x40c24e4 0x0 0x0)
0x345e7da8 : 0x900d85 (0x3e72800 0x3ff0900 0x0 0x0)
0x345e7e48 : 0x901724 (0x3e72800 0x3f86508 0x0 0x0)
0x345e7ec8 : 0x901779 (0x3e72800 0x0 0x0 0x408ea0)
0x345e7ee8 : 0x8fa998 (0x3e72800 0x0 0x345e7f18 0x8faa7c)
0x345e7f18 : 0x41d149 (0x3e72800 0x0 0x1 0x19ccc1)
	Backtrace continues...
      Kernel loadable modules in backtrace (with dependencies):
         com.apple.iokit.IOUSBMassStorageClass(2.0.0)@0x91b000->0x924fff
            dependency: com.apple.iokit.IOSCSIArchitectureModelFamily(2.0.0)@0x7c5000
            dependency: com.apple.iokit.IOUSBFamily(3.0.3)@0x60d000
            dependency: com.apple.iokit.IOStorageFamily(1.5.2)@0x7dd000
         com.apple.driver.AppleUSBEHCI(3.0.3)@0x8f7000->0x908fff
            dependency: com.apple.iokit.IOPCIFamily(2.4)@0x63c000
         com.apple.iokit.IOUSBFamily(3.0.3)@0x60d000->0x634fff
BSD process name corresponding to current thread: kernel_task
Mac OS version:
9B18
Kernel version:
Darwin Kernel Version 9.1.0: Wed Oct 31 17:46:22 PDT 2007; root:xnu-1228.0.2~1/RELEASE_I386
System model name: Macmini2,1 (Mac-F4208EAA)
Model: Macmini2,1, BootROM MM21.009A.B00, 2 processors, Intel Core 2 Duo, 1.83 GHz, 2 GB
Graphics: kHW_IntelGMA950Item, GMA 950, spdisplays_builtin, spdisplays_integrated_vram
Memory Module: BANK 0/DIMM0, 1 GB, DDR2 SDRAM, 667 MHz
Memory Module: BANK 1/DIMM1, 1 GB, DDR2 SDRAM, 667 MHz
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x86), 1.2.2
Bluetooth: Version 2.0.0f20, 2 service, 1 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Network Service: Parallels Host-Guest, Ethernet, en3
Network Service: Parallels NAT, Ethernet, en4
Serial ATA Device: Hitachi HTS541680J9SA00, 74,53 GB
Parallel ATA Device: MATSHITACD-RW  CW-8124
USB Device: USB2.0 Storage Device, Cypress Semiconductor, high_speed, 500 mA
USB Device: hub_device, high_speed, 500 mA
USB Device: cyberJack pinpad(a), Reiner-SCT, full_speed, 500 mA
USB Device: CanoScan, Canon, full_speed, 500 mA
USB Device: USB Receiver, Logitech, low_speed, 500 mA
USB Device: Bluetooth USB Host Controller, Apple, Inc., full_speed, 500 mA
USB Device: IR Receiver, Apple Computer, Inc., full_speed, 500 mA
Kann damit jemand was anfangen? Danke.
dazu weiss wohl keiner was? :frowning:
Sorry, aber so einem Crash Log kann unsereiner nicht viel mehr entnehmen als dass sich der Kernel bei einem IO auf eine USB Platte verschluckt hat :confused:
Soweit dürfte dir die Situation selber bekannt sein.
Für weitere Erkenntnisse müsste man den Crashdump auswerten, wozu aber nur die Jungs bei Apple die Tools haben und man schon erhebliches Wissen über den Kernel zur Auswertung der Ergebnisse braucht.
Zur Problembehebung kann ich nur die allgemeinen Tipps zu USB Problemen geben - mal alle anderen Geräte weg, weg mit einem ev. vorhandenen HUB, Kabel tauschen,…
Ansonsten könntest du es auch mal mit einer anderen Platte probieren, idealerweise eine mit USB und Firewire.
So, ich hab jetzt die USB Platte direkt an den Mac gehängt (vorher am Hub) und
es ist anstandslos durchgelaufen. :smile: Danke @Jonny.
Oh, schön wenn ich dir mit diesen einfachen Tipps helfen konnte :smiley:
