Das glaube ich eher nicht.
Warum sollte der Speichercontroller nicht damit zurechtkommen ?
Haette jemand - der einen Mini mit 4GB ausgeruestet hat - die guete mal Linux Ubuntu zu booten - und ein: “sudo lspci -v” ausfuehren - das Ergebnis hier reinposten…
Dann koennten wir mal genau vergleiche - was so im mini drinnsteck …
Hier schaut das lspci -v eines Ende 2006 gekauften mini’s
[code]
~$ sudo lspci -v
[sudo] password for smurphy:
00:00.0 Host bridge: Intel Corporation Mobile 945GM/PM/GMS, 943/940GML and 945GT Express Memory Controller Hub (rev 03)
Subsystem: Intel Corporation Unknown device 7270
Flags: bus master, fast devsel, latency 0
Capabilities: [e0] Vendor Specific Information
00:02.0 VGA compatible controller: Intel Corporation Mobile 945GM/GMS, 943/940GML Express Integrated Graphics Controller (rev 03) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at 90380000 (32-bit, non-prefetchable) [size=512]
I/O ports at 20f0 [size=8]
Memory at 80000000 (32-bit, prefetchable) [size=256]
Memory at 90400000 (32-bit, non-prefetchable) [size=256]
Capabilities: [90] Message Signalled Interrupts: Mask- 64bit- Queue=0/0 Enable-
Capabilities: [d0] Power Management version 2
00:07.0 Performance counters: Intel Corporation Unknown device 27a3 (rev 03)
Flags: 66MHz, fast devsel, IRQ 10
Memory at 90444000 (32-bit, non-prefetchable) [size=4]
Capabilities: [dc] Power Management version 2
00:1b.0 Audio device: Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller (rev 02)
Subsystem: Sigmatel Unknown device 7680
Flags: bus master, fast devsel, latency 0, IRQ 21
Memory at 90440000 (64-bit, non-prefetchable) [size=16]
Capabilities: [50] Power Management version 2
Capabilities: [60] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable-
Capabilities: [70] Express Unknown type IRQ 0
00:1c.0 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 1 (rev 02) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00001000-00001fff
Memory behind bridge: 90200000-902fffff
Prefetchable memory behind bridge: 0000000090500000-00000000905fffff
Capabilities: [40] Express Root Port (Slot+) IRQ 0
Capabilities: [80] Message Signalled Interrupts: Mask- 64bit- Queue=0/0 Enable+
Capabilities: [90] Subsystem: Gammagraphx, Inc. Unknown device 0000
Capabilities: [a0] Power Management version 2
00:1c.1 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 2 (rev 02) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
Memory behind bridge: 90100000-901fffff
00:1d.0 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #1 (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 18
I/O ports at 20a0 [size=32]
00:1d.1 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #2 (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 19
I/O ports at 2080 [size=32]
00:1d.2 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #3 (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 20
I/O ports at 2060 [size=32]
00:1d.3 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #4 (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 17
I/O ports at 2040 [size=32]
00:1d.7 USB Controller: Intel Corporation 82801G (ICH7 Family) USB2 EHCI Controller (rev 02) (prog-if 20 [EHCI])
Memory at 90445400 (32-bit, non-prefetchable) [size=1]
Capabilities: [58] Debug port
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e2) (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=32
Memory behind bridge: 90000000-900fffff
Capabilities: [50] Subsystem: Gammagraphx, Inc. Unknown device 0000
00:1f.0 ISA bridge: Intel Corporation 82801GBM (ICH7-M) LPC Interface Bridge (rev 02)
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 02) (prog-if 8a [Master SecP PriP])
I/O ports at 01f0 [size=8]
I/O ports at 03f4 [size=1]
I/O ports at 0170 [size=8]
I/O ports at 0374 [size=1]
I/O ports at 20c0 [size=16]
00:1f.2 IDE interface: Intel Corporation 82801GBM/GHM (ICH7 Family) SATA IDE Controller (rev 02) (prog-if 8f [Master SecP SecO PriP PriO])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 19
I/O ports at 20d8 [size=8]
I/O ports at 20fc [size=4]
I/O ports at 20d0 [size=8]
I/O ports at 20f8 [size=4]
I/O ports at 2020 [size=16]
Memory at 90445000 (32-bit, non-prefetchable) [size=1]
Capabilities: [70] Power Management version 2
00:1f.3 SMBus: Intel Corporation 82801G (ICH7 Family) SMBus Controller (rev 02)
Flags: medium devsel, IRQ 11
I/O ports at efa0 [size=32]
01:00.0 Ethernet controller: Marvell Technology Group Ltd. 88E8053 PCI-E Gigabit Ethernet Controller (rev 22)
Subsystem: Marvell Technology Group Ltd. Marvell RDK-8053
Flags: bus master, fast devsel, latency 0, IRQ 221
Memory at 90200000 (64-bit, non-prefetchable) [size=16]
I/O ports at 1000 [size=256]
Expansion ROM at 90500000 [disabled] [size=128]
Capabilities: [48] Power Management version 2
Capabilities: [50] Vital Product Data
Capabilities: [5c] Message Signalled Interrupts: Mask- 64bit+ Queue=0/1 Enable+
Capabilities: [e0] Express Legacy Endpoint IRQ 0
02:00.0 Ethernet controller: Atheros Communications Inc. AR242x 802.11abg Wireless PCI Express Adapter (rev 01)
Subsystem: Apple Computer Inc. Unknown device 0086
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at 90100000 (64-bit, non-prefetchable) [size=64]
Capabilities: [40] Power Management version 2
Capabilities: [50] Message Signalled Interrupts: Mask- 64bit- Queue=0/0 Enable-
Capabilities: [60] Express Legacy Endpoint IRQ 0
Capabilities: [90] MSI-X: Enable- Mask- TabSize=1
03:03.0 FireWire (IEEE 1394): Agere Systems FW323 (rev 61) (prog-if 10 [OHCI])
Subsystem: Agere Systems FW323
Flags: bus master, fast Back2Back, medium devsel, latency 248, IRQ 19
Memory at 90000000 (32-bit, non-prefetchable) [size=4]
Capabilities: [44] Power Management version 2
[/code][/size][/size][/size][/size][/size][/size][/size][/size][/size][/size][/size][/size][/size][/size][/size][/size][/size][/size][/size][/size][/size][/size][/size][/size][/size][/size][/size][/size]
