Mein neuer MAC mini mag nicht aufwachen :(
Bidschirm wacht nach Ruhezustand nicht auf.
Ich höre nur das Superdrive einmal surrren.
Mehr nicht. Nach Hard.Reset kommt er dann hoch.
Hat jemand eine Idee?
Hier das Log:
31.01.09 13:06:24 kernel vmmon: powerStateDidChange flags=0x4 (state 2) 31.01.09 13:06:24 kernel System Sleep 31.01.09 19:11:09 kernel Wake reason = USB2 31.01.09 19:11:09 kernel System Wake 31.01.09 19:11:09 kernel vmmon: powerStateDidChange flags=0x82 (state 4) 31.01.09 19:11:09 kernel USB (UHCI):Port 1 on bus 0x3d has remote wakeup from some device 31.01.09 19:11:09 kernel vmnet: VMNetDisconnect called for port 0x3b64e00 31.01.09 19:11:09 kernel vmnet: bridge-en1: filter detached 31.01.09 19:11:09 kernel vmnet: bridge-en1: down 31.01.09 19:11:09 kernel vmnet: bridge-en1: detached 31.01.09 19:11:09 kernel vmnet: Freeing hub at 0x3376800. 31.01.09 19:11:09 kernel EIR is not supported. 31.01.09 19:11:09 airportd[247] FastFinder scanning channels again 31.01.09 19:11:09 airportd[247] Could not find "meinWLANname" 31.01.09 19:11:09 airportd[247] Could not find any preferred networks; trying broadcast requests.. 31.01.09 19:11:11 kernel 11D beacon causing regdomain change to CC 276 31.01.09 19:11:11 kernel en1: 802.11d country code set to 'DE'. 31.01.09 19:11:11 kernel en1: Supported channels 1 2 3 4 5 6 7 8 9 10 11 12 13 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 31.01.09 19:11:14 kernel AirPort: Link Up on en1 31.01.09 19:11:14 ntpd[25] sendto(17.72.255.12) (fd=28): Can't assign requested address 31.01.09 19:11:15 kernel vmnet: VNetUserIf_Create: created userIf at 0x3b64a00. 31.01.09 19:11:15 kernel vmnet: VMNetConnect: returning port 0x3b64a00 31.01.09 19:11:15 kernel vmnet: Hub 0 does not exist, allocating memory. 31.01.09 19:11:15 kernel vmnet: Allocated hub 0x3701000 for hubNum 0. 31.01.09 19:11:15 kernel vmnet: VMNET_SO_BINDTOHUB: port: paddr 00:50:56:ef:2f:7c 31.01.09 19:11:15 kernel vmnet: Hub 0 31.01.09 19:11:15 kernel vmnet: Port 0 31.01.09 19:11:15 kernel vmnet: bridge-en1: got dev 0x3627a04 31.01.09 19:11:15 kernel vmnet: bridge-en1: wireless interface detected. 31.01.09 19:11:15 kernel vmnet: bridge-en1: up 31.01.09 19:13:29 kernel npvhash=4095 31.01.09 19:13:26 com.apple.launchctl.System[2] fsck_hfs: Volume is journaled. No checking performed. 31.01.09 19:13:26 com.apple.launchctl.System[2] fsck_hfs: Use the -f option to force checking.
MAC mini, Core2Duo 2.0 GHz, 1 GB RAM, 120 GB HDD
Darwin Mac-mini.local 9.6.0 Darwin Kernel Version 9.6.0: Mon Nov 24 17:37:00 PST 2008; root:xnu-1228.9.59~1/RELEASE_I386 i386
Installierte SW VM Ware Fusion Version 2.0.1 (128865)
Und elgato eyetv diversity mit EyeTV 3.1 (4513)
Der Rest kam erst später - der Fehler besteht aber seit dem 1. Tag.
:angry:
Wenn der Recher nur kurz in den Ruhezustand versetzt wird, tritt der Fehler nicht auf.
Nur nach längerer Pause ist er nicht mehr wachzurütteln.
Um 19:11 h versucht zu wecken - um 19:13 h hart neu gebootet.
Wäre für Tipps dankbar.
Wörsty
Ähnliches passiert bei meinem C2D- Macmini, wenn ich ihn per Tastatur in den Ruhestand schicke … :confused:
Wenn ich mit der Maus im Apfelmenü den Ruhezustand auswähle,
dann wacht er immer normal auf, bei Tastendruck ect … :wink:
Ich würde mal alles außer Maus und Tastatur abstöpseln, mal sehen ob es dann besser wird.
Rechte reparieren und Komboupdate drüberbügeln könnte auch helfen.
Ich würde auf einen verhakten Treiber tippen.
Häufig sind leicht vergurkte USB-Hubs schuld an sowas. Damit würde ich mal anfangen zu experimentieren, wie Jonny vorgeschlagen hat - also abstöpseln, und evtl. auch andere Kombinationen von “am Hub”/“am Mini” durchtesten.
Werde das mal testen.
Angeschlossen war nur mein Wireless Keyboard (Dieses Apple Alu Ding) und meine Maus (Logitech MX Air)
Hubs sind keine dran.
Wireless LAN ist aktiviert.
So mach ich es auch.
Sowas hatte ich bei meinem allerersteb Mini auch mal - hatte aber weder Zeit noch Ahnung um der Sache auf den Grund zu gehen und habe dann einfach das System neu aufgesetzt. Das hat das Problem gelöst.
04.02.09 07:35:46 kernel System Sleep 04.02.09 19:17:12 kernel Wake reason = PWRB 04.02.09 19:17:12 kernel System Wake 04.02.09 19:17:12 kernel vmmon: powerStateDidChange flags=0x82 (state 4) 04.02.09 19:17:12 kernel EIR is not supported. 04.02.09 19:17:14 kernel 11D beacon causing regdomain change to CC 276 04.02.09 19:17:14 kernel en1: 802.11d country code set to 'DE'. 04.02.09 19:17:14 kernel en1: Supported channels 1 2 3 4 5 6 7 8 9 10 11 12 13 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 04.02.09 19:17:16 kernel AirPort: Link Up on en1 04.02.09 19:17:22 kernel vmnet: VNetUserIf_Create: created userIf at 0x4e20600. 04.02.09 19:17:22 kernel vmnet: VMNetConnect: returning port 0x4e20600 04.02.09 19:17:22 kernel vmnet: VMNET_SO_BINDTOHUB: port: paddr 00:50:56:e4:75:1c 04.02.09 19:17:22 kernel vmnet: Hub 0 04.02.09 19:17:22 kernel vmnet: Port 0 04.02.09 19:17:22 kernel vmnet: Port 1 04.02.09 19:17:22 kernel vmnet: Port 2 04.02.09 19:17:22 kernel vmnet: bridge-en1: got dev 0x34f2e04 04.02.09 19:17:22 kernel vmnet: bridge-en1: wireless interface detected. 04.02.09 19:17:22 kernel vmnet: bridge-en1: up 04.02.09 19:17:22 kernel vmnet: bridge-en1: attached 04.02.09 19:17:22 kernel vmnet: VNetUserIfFree: freeing userIf at 0x4e20600. 04.02.09 19:19:12 com.apple.launchd[1] (com.apple.backupd-wake[1231]) Exited with exit code: 1 04.02.09 19:21:30 kernel PRB0_TAIL: 00000078 04.02.09 19:21:30 kernel PRB0_HEAD: 00600084 04.02.09 19:21:30 kernel PRB0_STRT: 02120000 04.02.09 19:21:30 kernel PRB0_LEN: 00000803 04.02.09 19:21:30 kernel SRB0_TAIL: 00000000 04.02.09 19:21:30 kernel SRB0_HEAD: 00000000 04.02.09 19:21:30 kernel SRB0_STRT: 02121000 04.02.09 19:21:30 kernel SRB0_LEN: 00000003 04.02.09 19:21:30 kernel PGTBL_CTL: 3ffc0001 04.02.09 19:21:30 kernel PGTBL_ERR: 00000000 04.02.09 19:21:30 kernel EXCC: 00000000 04.02.09 19:21:30 kernel IPEIR: 00000000 04.02.09 19:21:30 kernel IPEHR: 01800002 04.02.09 19:21:30 kernel INSTDONE: 7fffffc1 04.02.09 19:21:30 kernel NOPID: 00000000 04.02.09 19:21:30 kernel HWSTAM: ffffffff 04.02.09 19:21:30 kernel IIR: 00000000 04.02.09 19:21:30 kernel IMR: fffdff3f 04.02.09 19:21:30 kernel ISR: 00000000 04.02.09 19:21:30 kernel EIR: 00000000 04.02.09 19:21:30 kernel EMR: ffffffff 04.02.09 19:21:30 kernel ESR: 00000000 04.02.09 19:21:30 kernel INSTPM: 00000000 04.02.09 19:21:30 kernel INSTPS: 800f0040 04.02.09 19:21:30 kernel ACTHD: 0266a034 04.02.09 19:21:30 kernel MEM_MODE: 00000000 04.02.09 19:21:30 kernel DMA_FADD_P 0266a800 04.02.09 19:21:30 kernel DMA_FADD_S 00000000 04.02.09 19:21:30 kernel MI_STATE 00000040 04.02.09 19:21:30 kernel PR0_STR: 0266a033 04.02.09 19:21:30 kernel PR0_END: 00000000 04.02.09 19:21:30 kernel CCID0: 00000000 04.02.09 19:21:30 kernel CTX_SIZE_PAL: 00000009 04.02.09 19:21:30 kernel CTX_SIZE_NOPAL: 00000003 04.02.09 19:21:30 kernel 3D_CTL: 00000307 04.02.09 19:21:30 kernel CHUNK_CTL: 00000000 04.02.09 19:21:30 kernel HWB_TAIL: 00000000 04.02.09 19:21:30 kernel HWB_HEAD: 00000000 04.02.09 19:21:30 kernel HWB_START: 00000000 04.02.09 19:21:30 kernel HWB_CTL: 003ff000 04.02.09 19:21:30 kernel BIN_CTL: 00000000 04.02.09 19:21:30 kernel BIN_SCENE: 00000000 04.02.09 19:21:30 kernel BMP_BUFER: 00000000 04.02.09 19:21:30 kernel BMP_GET: 00000000 04.02.09 19:21:30 kernel BMP_PUT: 00000000 04.02.09 19:21:30 kernel ICS: 00000003 04.02.09 19:21:30 kernel ISP: 00000000 04.02.09 19:21:30 kernel FSI: 00000000 04.02.09 19:21:30 kernel SSI: 00000000 04.02.09 19:21:30 kernel FST: 00000000 04.02.09 19:21:30 kernel SST: 00000000 04.02.09 19:21:30 kernel INTC: 00000000 04.02.09 19:21:30 kernel IDLC: 00000000 04.02.09 19:21:30 kernel SVDebug 00000003 04.02.09 19:21:30 kernel SHDebug 00480000 04.02.09 19:21:30 kernel SFDebug 01878de0 04.02.09 19:21:30 kernel SEDebug c0027100 04.02.09 19:21:30 kernel WMDebug 020d0000 04.02.09 19:21:30 kernel IZDebug0 20000021 04.02.09 19:21:30 kernel IZDebug0 00000000 04.02.09 19:21:30 kernel PIDebug0 01807ff4 04.02.09 19:21:30 kernel PIDebug1 00000000 04.02.09 19:21:30 kernel PIDebug2 01807ff4 04.02.09 19:21:30 kernel DIPDebug 040f7e34 04.02.09 19:21:30 kernel PLDebug 00000180 04.02.09 19:21:30 kernel DGDebug 00000010 04.02.09 19:21:30 kernel QCDebug 00000000 04.02.09 19:21:30 kernel FTDebug 00000000 04.02.09 19:21:30 kernel DMDebug 00000010 04.02.09 19:21:30 kernel SCDebug 003ca184 04.02.09 19:21:30 kernel FLDebug 31030040 04.02.09 19:21:30 kernel BYDebug 00055440 04.02.09 19:21:30 kernel PSDebug 024ec000 04.02.09 19:21:30 kernel CCDebug 002c0640 04.02.09 19:21:30 kernel status[ISR]: 00000000 04.02.09 19:21:30 kernel status[PRB0_HEAD]: 00600074 04.02.09 19:21:30 kernel status[SRB0_HEAD]: 00000000 04.02.09 19:21:30 kernel status[SRB1_HEAD]: 00000000 04.02.09 19:25:37 kernel npvhash=4095 04.02.09 19:25:32 com.apple.launchctl.System[2] fsck_hfs: Volume is journaled. No checking performed.
Immer noch - Neuaufsetzen ist keine Option.
Wie hast du den Mini an den Monitor angeschlossen, über DVI oder VGA, und an welchem Monitor? Wenn ich meine Kiste über DVI an meinen Samsung Syncmaster anschließe bekomme ich beim Aufwachen auch kein Bild mehr, über VGA geht es. Ich schalte den Sleepmode aber sowieso komplett ab.
Und welche von den vorgeschlagenen Maßnahmen hast du inzwischen umgesetzt?
DVI - interessant, dass du das auch hast.
Wie bekomme ich Sleep komplett aus?
Die Rechte hab ich repariert.
Geräte abgezogen.
War denn nochwas?
Naja, in den Systemeinstellungen unter ‘Energie sparen’ einfach alles abschalten bzw. die Regler ganz nach rechts schieben.
Ok. Habe ich.
Werde das weiter beobachten.
